Sensirion sht7x labview
Thanks Mooseo
I have bought the Evaluation Kit from Sensirion (USB connection and driver for the sensor). But it'll take too long time to get it, so I have to start working now.
Ain't there any models for Serial Port control, the way you described it?
Message 61 of 85
(3,183 Views)
But why use some sort of serial port module when you can use a USB device?
Message 62 of 85
(3,167 Views)
I've been using SHTxx sensors for a while and everything works nicely with 6009 and via serial communication.
Have anyone made this work with a cRIO using a DIO module?
Message 63 of 85
(3,136 Views)
I was able to interface with the Sensirion sht75 with the following code and connections. The connection is as follows:
SHTxx                                DAQ
______                              _________________
GND   |-------------------------|   GND                          |
5V       |---+--------------------|  +5V                            |
SCK    |---|---------------------| CLK digital port 0      |
DATA |---|----------+---->|---| read digital port 1      |
            |    |             |----------| write digital port 2      |
_____|     |             |            |_________________|
Resistor
I had the three digital lines for CLK, read, and write on port0.0, port0.1, and port0.2, respectively. I connected a 10K pull up resistor between 5V and DATA. I directly connected the write output from the DAQ to the DATA. And I connected the read input to the DAQ to the DATA via a diode with the positive end connected to DATA.
Hope this helps somebody,
-Crad
Message 64 of 85
(3,073 Views)
Hi everyone
I receive recently a free sample of the new temperature humidity sht21 sensirion sensor. I try to use the shtxxx driver, aparetly it works with ni6008, but the output values are wrong.
It seems the error becomes from the s_connectionreset.vi in the task in it gives an output of ERR (-200.....).
Can anyone help me to define the task in? I only change the physical address ports but the tasks I don't know.
Best regards from Portugal
CPalha
Message 65 of 85
(3,041 Views)
Hi Cpala,
I don't think that the drivers work with the 6008... they require the Tri-state property to use the same pin as input and output, but the 6008 doesn't support that.
It wouldn't be too tough to change them to use a different pin for input and output. If you go back to Marios earliest versions, I seem to recal that he used separate pins.
Good luck.
mike
Message 66 of 85
(3,032 Views)
Hi
We spent a great deal of time also making this sensor work on a cRIO with a 9401 DIO module, but never got it to work. If anyone has had succes with this let me know.
soeren
Message 67 of 85
(3,022 Views)
Hi mooseo
Thanks for the reply.
I confirm that I had used the Mario diagram, but in the lbb file it has many VI's. One of them, I think the only one that gives an output error  (s_connectionreset.vi) because the "Task in" is empty in the front panel. I need to know what information I need to put there.
Regards from Pt
CPalha
Message 68 of 85
(3,017 Views)
Hi everyone
I discovery the error about task in.
Was a bad solder in the sht21, very small and far conditions to solder. I use the SHT11 and it works good.
After compare with a good equipement to measure temp and hum, I can say to the forum that sensor has good accurancy.
regards from pt, brg
CPalha
Message 69 of 85
(3,001 Views)
Hello Mooseo,
I am trying to make your multiple sensor SHTxx code work, but I am unable to see the modification that enables it to read multiple sensors. You talked about a common SCK line and then indivudual data i/o line. Where do I select the data i/o lines for my additional sensors? Right now I am trying to get two sensors to work, but eventually I will need to read temp and humidity from 8 sensors.
Thanks in advance for your help!
Message 70 of 85
(2,794 Views)
