Sensor Mapping VI configuration window freezes whenever a .STL file is loaded
The Sensor Mapping VI gets frozen whenever I load a .stl file and the black screen doesn't display any model representation. In the other hand the same model in a .wrl format works fine. Could anyone help me with this issue?
I have LabVIEW 2010 SP1 evaluation version.
thanks in advance.
(3,096 Views)
Accepted by topic author uxpro
Hi uxpro
I think you may have your .stl file in a binary format instead of an ASCI format, this may be the reason of the freeze
Regards
Julio Mena
(3,087 Views)
Tnx for the clue. I'll try it, and then I'll let you know if it works.
(3,085 Views)
Thanks it worked, I'd export the file in ASCII format and LabVIEW loaeded it seamless.Smiley Surprised
(3,074 Views)
