Sensor
How to make Ultrasonic Sensor Simple for Distance in Labview in Window
(1,572 Views)
That's like posting a question  "How do I drive a car?"
Read  http://www.catb.org/~esr/faqs/smart-questions.html
Then provide some details for what you are trying to do, the steps you've taken in LabVIEW, and where you are stuck.
(1,562 Views)
Simple: Use a US-piezo disc, connect it to the line in of your soundcard.
If an object is crashing the piezo, you get a signal and you know the distance is zero 😄
Serious: look for a sensor that matches  the connection capabilities you have.... and the budged you have 😉
Greetings from Germany
Henrik
LV since v3.1
(1,511 Views)
