Sensors in data acquisition program batch management
hello everyone!
        Now,   I am trying  to development a big application about Aviation test system. I have two problems needs to solve.
     1)   I  want to know how to develop a complete application about  Aviation test system.Include DAQ  ,save , display and playback.Had better have relevant examples or have some tutorial.
    2) I saw somebody develop  Aviation test system,He use a application  name is data manager.In this application ,he can    configuration sensors'(see appendix)type include The input signal types ,The maximum value ,minimum value and With the matching  maximum value ,minimum value.For example:sensors' type is current ,value is (4-20mA),With the matching value is (0-35Mpa).when need  increase sensor ,we only  need at the data manager .vi congfiger.
thank you very much!
yangzhen
Message 1 of 1
(3,058 Views)
