Sensors specifications
Are all sensors compatible with LabVIEW  and DAQ assisstant or are there any specifications ?
(4,349 Views)
Sensors have nothing to do with LabVIEW or the DAQ assistant.
The question is whether you have a DAQ device that is cabable of reading your sensor.
(4,346 Views)
As Ravensfan points out, the burden is on the daq.
From my experience, some sensors require differential inputs on the daq(ie- many single pwr supply sensors)  Also, want  the sensor output to be within range of daq. (some daqs limited on neg side)  Lastly, you want 2 be sure that daq can read  beyond the normal range of the sensor so you can detect an overrange condition.
good luck
(4,285 Views)
Environment > Sensor > Signal > DAQ Device > LabVIEW > User
This is the general idea.
My guess is you're asking about DAQ Devices in general. LabVIEW and MAX are great at working with a wide range of devices, though NI equipment is obviously the easiest.
Cheers
(4,273 Views)
How to calibrate MQ-3 sensor using LabVIEW 14.0 ?
(4,167 Views)
Hi aishu,
such a question should be answered in the calibration manual of the sensor manufacturer!
If the manufacturer of this (cheap) sensor doesn't provide any calibration data/manual you could look for similar (but better) gas sensors and read their calibration manual. Then apply your new knowledge to your sensor…
Hint: to calibrate gas sensors you need gas compositions with known content…
(4,142 Views)
