SentinelOne and 2025 Crashes
Hello all,
We (relatively) recently upgraded our systems from LV 2021 to 2025 and also immediately started seeing tons of crashes. Labview would just close completely. I’ve sent crash logs to NI but didn’t get super far. I’ve also done some testing running the same code on the same computer in 2021 and 2025, and 2025 crashes after only a few minutes while 2021 will run for hours. Never had issues with these codes in the past.
Windows event viewer keeps pointing to our company security software, SentinelOne, as a source of problems. Multiple machines running multiple codes written on the same codebase affected. All Win11.
Has anyone else noticed any reliability problems with LV 2025 and/or SentinelOne?
Thanks!
(432 Views)
Just do a google search for "SentinelOne interference".
Instead of working with NI on the problem, you should talk to IT and even SentinelOne. Maybe you can define exclusions to protect your LabVIEW sessions.
(410 Views)
Crosspost from Reddit: most probably just SPAM…
(371 Views)
