Separating Channel list into Columns?
I have Thermocouple channel list set up on my VI already as well as build table and various other outputs. I was wondering if there was a way to separate the channel list so that each channel has it's own data column on the table. Sorry, I'm new at LabVIEW.
(3,059 Views)
Please share your VI with some data that you are seeing. In order to save it with some data, do the following:
  1. Run your VI
  2. Go to block diagram and right click on your indicator (array, graph, etc)
  3. Select Create Constant
The constant should have some data in it. Then Save your VI and post it here. Thank you,
(3,051 Views)
