Sequence Generation
Can anyone help me how to generate the sequence as below. Output is array of 3 elements and input is number of iteration.
No of Iteration Index 0 Index 1 Index 2
5 0 0 5
10 0 5 10
15 5 10 15
20 5 10 20
25 5 15 25
30 10 20 30
n x y z
Message 1 of 8
(4,143 Views)
Hi vargeeshj,
search the "number of iteration" in the first column of your 2D array, when found you output the corresponding "index" values of the found row…
Message 2 of 8
(4,140 Views)
Hi GerdW,
Thanks for the reply. As mentioned already number of iteration is the input for the program and the output is array of 3 elements
Message 3 of 8
(4,138 Views)
Do you have an algorithm that describes this, or are you just trying to get us to do your homework for you?
Message 4 of 8
(4,135 Views)
If i have an algorithm, I could have made it myself.
Message 5 of 8
(4,133 Views)
Accepted by topic author vargeeshj
looks like your algorithm is index1=(iterations / 15) *5, index2=(iterations / 7)*5, index3=iterations.
I'm guessing this is not just purely a mathematical exercise though.
You can achieve the modulus operations using the Remainder and Quotient function.
EDIT: I initiallly wrote out as modulus operations but you really want integer quotient.
Message 6 of 8
(4,122 Views)
Your example is insufficient to identify a pattern. For example:
  • What should the output be if the input is not a multiple of five?
  • What if the input is zero or negative?
  • Is there an upper limit for N?
  • The third element (Index 2) is trivial and just seem to repeat the input, but what about the first and second output element?
  • "Index" is a somewhat reserved word with a special meaning. Why not use a different term?
  • Can you give us some background information on where this should be used? What's the purpose?
Message 7 of 8
(4,117 Views)
The input is always multiple of 5 only.
Hence the type is unsigned, negative is taken care and zero is also not a valid input.
No. But is is multiple of 5.
Thats the pattern what am looking for.
  • "Index" is a somewhat reserved word with a special meaning. Why not use a different term.
Message 8 of 8
(4,107 Views)
