Sequence Output Mode for PXIe-4140
I need to configure one channel of my SMU (PXIe-4140) to source a sequence of voltages for specific time, I the programming based on what I found in help but the SMU only sources the first value that I set.
(2,887 Views)
The Sub VI 'Set Sequence'
only accepts array values.
So, if I understand your request correctly:
 you want to set the single voltages in the Set Sequence.vi one by one in a specific sequence, for a certain amount of time?
Greetings and Regards,
James
(2,812 Views)
