Sequence execution
can anybody send me and example  of the other way of doing the sequence execution??
Message 11 of 33
(3,488 Views)
Here is an example of adding with a wait using a state machine.
Message 12 of 33
(3,483 Views)
Hi : Can you send the example in Labview 8.0 or an image??
Message 13 of 33
(3,463 Views)
Try this one out.
Message 14 of 33
(3,460 Views)
Hi there,
I've just read your post and I'm interested to find out where did you get the flat sequence structure from? I'm using labview 6.1 and I haven't been able to locate this one yet.
thanks
Badis
Message 15 of 33
(3,388 Views)
The flat sequence wasn't added until LabVIEW 7.
I would say it's about time to upgrade.Smiley Wink
Message 16 of 33
(3,386 Views)
I wouldn't upgrade just for the flat sequence
try using the state machine concept to perform sequences.  that way you can edit your sequence very easy.
if you are up for a small learning curve download the state machine design pattern from the openG toolkit and learn that model.  you can then use what they term macros to script a sequence of states
- James
Using LV 2012 on Windows 7 64 bit
Message 17 of 33
(3,381 Views)
No, of course not.  But so much else as changed since then as well.  How old is LV6?  About 6 years old?
Message 18 of 33
(3,376 Views)
>sequences are evil
Now, now, they aren't always evil:
Sequences are a tool for explicit control of execution order. People often promote using error cluster wiring to control execution order, but I think that's evil, because wiring error clusters for the goal of handling errors is a clear and well defined use of error wires, and doing it for some other goal obscures the programming intent. It's a programming trick, and programming tricks are fun and clever for a day and then turn into traps for the next time the code is examined.
Besides, if it weren't for sequences, we wouldn't have the biggest glyph in the LabVIEW icon!
Message 19 of 33
(3,365 Views)
Well what happens when you have a sequence with 15 frames and you want to re-arrange frames 3,5,8 and 12 but you only want to do that in certain instances
do you still suggest using a sequence?
That is why i suggested to use a scripted state machine
- James
Message 20 of 33
(3,363 Views)
