Sequence structure "reuse"?
I have an application that requires me to make measurements in a
particular order at specific times and to update a set of indicators
as the measurement progresses. I use a sequence structure in which
different frames write to local variables keyed off the indicators. I
now need to replicate this sequence in a couple of other places.
Unfortunately, copy/paste of the sequence results in new front panel indicators and
variables being created. While I could change each one manually, with
25 frames and multiple locals, the time required is huge and the
possibility of errors is high as the number of copy/pastes increases.
Creating a subVI has been problematic as the indicators must update as
I progress through the sequence.
The subVI terminals update only on
conclusion, as far as I have been able to find. Globals are an
option, but, I am wary of using them.
I believe the creation of new variables on paste is how LV is
structured (ie. this is not a bug but the way things are). I need a
workaround, though, and would appreciate suggestions.
--- Ravi
Ravi Narasimhan
Dept. of Physics and Astronomy, UCLA
http://www.physics.ucla.edu/~oski
(3,248 Views)
Yes copy /paste makes new variables.
I dont guess you have version 6. Using the control refnum in 6i
will do what you want. The only way I can think of to solve this
SIMPLY is to move the locals OUT
of the sequence. If you
do this then the copy / paste DOES NOT create new variables.
I would suggest that you try to rewrite this WITHOUT the sequnces.
They have their uses, but can become a crutch and a trap (as you have found).
Kevin Kent
(3,248 Views)
[ Copying sequences in LV5.1.1 ]
> SIMPLY is to move the locals OUT of the sequence. If you
Kevin,
Right on the version. I am using LV 5.1.1. I bit the bullet, and
made the sequence into a separate VI although still with sequences in
it. This gives me the functionality I need although not in
the strictly "one-panel"
form I was trying to get beforehand.
I had tried to avoid locals but I could not seem to get around them. I
have five indicators that are updated in various subsets at different
times requiring a real-time update <-> sequence structure. Since it is not possible to have
multiple wires going to an indicator, I settled on locals. I was also
not able to get the VI structured in the form of a state machine (Case
inside a While loop method)...
Thanks for your advice.
--- Ravi
Ravi Narasimhan
(3,248 Views)
When you select and drag holding the Ctrl key, the code and locals are
cloned without creating new controls.
Jean-Pierre Drolet
"L. Ravi Narasimhan" a écrit dans le message
news: Pine.GSO.4.21.0012072241140.16501-100000@gauss...
unces.
found).
> Kevin,
> it. This gives me the functionality I need although not in the strictly
"one-panel"
> --- Ravi
> Ravi Narasimhan
(3,248 Views)
If you are using Labview 6, you can pass control references to subvi's and
the controls in the parent vi can be updated from the subvi using a property
node while the subvi is still running. This is a new feature in Labview 6.
>I have an application that requires me to make measurements in a>particular
order at specific times and to update a set of indicators>as the measurement
progresses. I use a sequence structure in which>different frames write to
local variables keyed off the indicators. I>now need to replicate this sequence
in a couple of other places.>>Unfortunately, copy/paste of the sequence results
in new front panel indicators and>variables being created. While I could
is huge and the>possibility of errors is high as the number of copy/pastes
increases.>>Creating a subVI has been problematic as the indicators must
update as>I progress through the sequence. The subVI terminals update only
on>conclusion, as far as I have been able to find. Globals are an>option,
but, I am wary of using them.>>I believe the creation of new variables on
paste is how LV is>structured (ie. this is not a bug but the way things are).
I need a>workaround, though, and would appreciate suggestions.>> ---
Ravi>>>--->Ravi Narasimhan>Dept. of Physics and Astronomy, UCLA>http://www.physics.ucla.edu/~oski>
(3,248 Views)
All of the problems with control references and local variables could have
been avoided if a state machine architecture had been used. IMHO sequence
structures have little value and should be avoided like the plague.
change each one manually, with>25 f
(3,248 Views)
