Sequential tasks with continous and simultaneous datalogging
I normally use Lab view only for data collection; however I need to create a VI which can do a sequential task at the same time as continuously logging data.
In brief, I have a pressure vessel which I want to record the pressure within throughout numerous pressurisation cycles. Each cycle consists of a number of sequential steps:
Close outlet valve, open inlet valve, close inlet valve at defined pressure, hold at defined pressure, open outlet valve. I am able to do the data logging and am able to do the cycling sequence in separate Vis. However I can't work out what structure I should be using to do these two tasks simultaneously. At present the cycling stages are executed as a flat sequence, but the data is only recorded at the end of every cycle.
A description of the correct structure, and or and example case of tutorial would be extremely helpful.
Carl
(3,360 Views)
Two loops.
1.  Data acquisition and logging.
2.  State machine that executes commands,
(3,352 Views)
I have tried your suggestion with a simple example, maybe I've missunderstood something, but it is not working for me. Please see attached vi.
How can i get this simple example to work?
(3,310 Views)
You can't run your stop button like that. It doesn't work.  Your top loop isn't even running because the data hasn't exited your lower loop yet.  Think dataflow!
(3,308 Views)
