Serial 485 to Stepper Motor
I am new to LabVIEW and need to control a stepper motor.
My available resources are two serial 485 ports.
The stepper motor is a Vexta PK266-02A
Is this  possible and if so how should I go about this?
~Rolin
Message 1 of 8
(3,326 Views)
Do you also have a motor drive with a RS-485 interface?
Message 2 of 8
(3,321 Views)
Not directly-  Stepper motors do not run off the power available from a serial port.  They operate from pulses of DC voltages Here is the spec for your model motor.
Typically there is a controller to generate trains of pulses to turn the motor and a driver to boost the power from the controller enough to actually make the motor turn.  Some of these can be programmed through a serial port it depends on the manufacturer.
Message 3 of 8
(3,319 Views)
I am doing work by my own which related to stepper motors and I would like to know how I can write a program to detect how many steps were missed and compensate missed steps and how I could calculate nomber of missed steps and finally how to generate additional steps forward or backward because I am the beginner of using labview so I do not know how I do them
Message 4 of 8
(3,301 Views)
Could you help me with my case please ?
Message 5 of 8
(3,300 Views)
Hi
I am doing work by my own which related to stepper motors and I would like to know how I can write a program to detect how many steps were missed and compensate missed steps and how I could calculate nomber of missed steps and finally how to generate additional steps forward or backward because I am the beginner of using labview so I do not know how can I do them ?
Many thanks
Message 6 of 8
(3,297 Views)
Hi
Many thanks
Message 7 of 8
(3,296 Views)
I would suggest picking out a good motor drive.  I believe most of the good controllers will take encoder input and perform the compensation for you.  Once you've got a motor controller and interface picked out, the folks on the board can help you out with specific questions.
Message 8 of 8
(3,294 Views)
