Serial Communication between microcontroller and LABVIEW
Hi all.
I written a code using the UART device driver of the ADUCM3029 microcontroller for baudrate detection. I have tried it working with a serial emulator(Realterm) which is when I hit the "Enter" key it detects the baudrate and printed it on the serial emulator. After that when I type any character, it will be echoed on the serial emulator, shown on the attached image.realterm serial emulator.pngrealterm serial emulator.png
So I want this to be replicated with LABVIEW and I am able to make some block diagram shown below, but to no avail it is not working. Need any help on what I need to do to make it working. Thanks.
Message 1 of 12
(3,045 Views)
Your LABVIEW code is setting the baud rate once.
Message 2 of 12
(3,024 Views)
Are you really trying to emulate a terminal?  See if this link helps.
Bill
CLD
(Mid-Level minion.)
Message 3 of 12
(3,008 Views)
Am I just being dumb, or is the image from that link not a real snippet? I love the idea, but it never seems to work unless you say the magic phrase, and wave your wand just right.
Message 4 of 12
(3,003 Views)
Sorry, I'm just getting started with Labview. Learning with tutorials on youtube and some documentations on the internet I could find.
Message 5 of 12
(2,978 Views)
I was responding to bilko. The link he gave has, what appears to be a snippet. Snippets are a LabVIEW (half) feature that allows code to be embedded in PNGs. As I said though, the feature is rarely used, and seems to need some special "magical" handling to work correctly.
Message 6 of 12
(2,973 Views)
I forgot what that is called. And I think it only worked with Internet Explorer.
I always prefer a VI.
Message 7 of 12
(2,960 Views)
Not really, but I want with what I'm working right now is that it will work the same as a terminal. Btw, I try the link you provided and made some tweak but it's not working for me.
Message 8 of 12
(2,950 Views)
@StevenD  ha escrito:
It still works (sometimes) but there is a whole chain of tools and technologies involved nowadays, that all might decide to “sanitize” the image. First your browser which you use to upload the image, then the forum software, the backend CRM database for the forum and any gateway in between and then the browser to view and download the image.
In the past it could also vary between browsers if you had to either drag the image out of the browser or rather explicitly download it through that browser.
The idea was a really good one back at that time but “technological progress” threw a lot of extra wrenches in the wheels of this. The embedding of extra image tags also can be used for less harmless purposes than what LabVIEW snippets ever possibly could do, so many browsers try to rather be safe than sorry.
Rolf Kalbermatter  My Blog
Message 9 of 12
(2,932 Views)
So my question is still valid, is that actually a snippet in the link? Or just an imposter?
aka magic!
Message 10 of 12
(2,915 Views)
