Serial Communication with myRio
Hye.Im trying to connect GD02Rev2.0 (driver for the g15 cube servo) with myRio. I have to connect the Rx Tx and Control pin of the driver to the myRio to run the motor. It seems like i have to create serial communication in labview.Can anyone help me on this.thanks.The driver looks like below:
(4,162 Views)
Hi ravinath,
Yes, you need to.
Keep in mind your motor driver works with (LV)TTL levels on the logic lines, so you CANNOT connect to a standard RS232 port! You need to use a level shifter - or GPIO lines from your myRIO…
(4,131 Views)
thank you for your reply.so how to create the functional blocks in labview for the serial communication?any examples please
(4,108 Views)
Hi ravinath,
use the example VIs coming with LabVIEW!
(Maybe there is also a special example for the myRIO, can't check that as I don't have the myRIO package installed.)
As said before: you will need some additional hardware to communicate with your motor driver…
(4,104 Views)
