Serial Communication
I have a custom built board that connects to the PC serial port and talk to it thru hyper terminal OK. But when I used the "Basic serial write and read.vi" from LabVIEW examples to communicate with my board then I can't read back the data consistently where as the hyper terminal reads back data perfectly every time. I have made sure serial configuration is the same for both cases.
What else do I miss ? Please give me some ideas. Thanks
Dan
(7,112 Views)
A common mistake is to not send a termination character. Are you sending a \r\n (Carriage Retrun\Line Feed) at the end of your commands?
(7,097 Views)
I do have \n\r at the end of my command. Does the oder of them matter ? \r\n or \n\r .
Dan
(7,054 Views)
It matters if the instrument is expecting them in a certain order.Smiley Wink It's easy to check to see if it matters with your board by simply swapping the characters.
(7,047 Views)
Hi Dennis,
I did try with the \r\n order after reading your first response. And surely enough, it WORKED most of the time. Smiley Very Happy Thanks a lot. You saved me a lot of troubleshooting hours.
Also thank you NI for having this discussion forum. You have saved people like me from a lot of headache!
Dan
(7,037 Views)
could you send me the vi file
i am also trying to do the same thing
to imitate the hyper terminal
thanks.
-Just a student-
(6,815 Views)
thanks.
Hi - try this. I found it on this site a while back. I think I may have modified it slightly for my particular application but it's still pretty generic.
Jon.
(6,796 Views)
