Serial Compatibility VI's not working in Labview 7.0
If you use the serpdrv driver you must copy this file into the same folder where your exe is located. This is and was neccessary with all LV versions.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 11 of 13
(735 Views)
I was tried to copy the file serpdrv into the folder where I run my exe, but it seems to not change the issue.
Message 12 of 13
(735 Views)
you have to put serpdrv into the folder wherer lvrt.dll (the LV runtime engine) is located, that worked for me
Message 13 of 13
(735 Views)
