Serial Comunication COM Port to FSK Half Duplex Modem
I need to create a half duplex modem that can be address via a COM port.  I have seen the FSK examples.  I can use them to generate FSK out of my analog device.  I cannot control the bit stream out of the MT Generate.  I tried the user input, but it then it no longer runs continuously.  I also have no clue how to attach the bit stream to the COM port.  I want to see an 11 bit (1 start, 8 payload, 1 stop, 1 parity) word that is modulated in FSK as a start.  If I could send hex from one putty terminal to another that would be ideal.
Message 1 of 1
(2,250 Views)
