Serial Connection Lost and Timeout
Soroush wrote:
The network cable has a twisted pair and the shield connector is used as the ground. Is it proper? or the shield conductor shall be different from the ground. (I suppose that the shield conductor should also be connected to the ground.)
A separate conductor should be used to tie the grounds of the two systems together if necessary, it should NOT be the shield.  The shield should be tied to ground, but only at one end.  If it is tied to both ends, then rather than shielding the twisted pair, it becomes a path for a noisy ground plane to induce noise on the communication wires it is enclosing.
Message 31 of 31
(718 Views)
