Serial LabView - 16bit microcontroller communication
I'm trying to make a Man - Maschine Interface (vizualization) between LabView and Infineon 167CR microcontroller. Communication between the both works fine, but I'm trying to figure out nice and convenient way to recognize the datas sent and to sort them so that I know whether it's engines temperature or engine speed data. Maybe someone already did something similar ???? Thanx in advance
(2,810 Views)
there are a variety of ways of doing this depending on how much flexibility you need. if the data packet contents are constant, define a 'start of message' character or sequence of characters. convert your datavalues into single-precision and convert to hex. append all these 4-byte strings and put your start of message at the beginning of the whole thing and transmit it. at the other end the receiver scans for the start of message and (after stripping it off) takes the remainder, breaks it up into 4-byte chunks and converts each chunk back into a single precision number. a number's position in the message defines the value it represents.
Certified LabVIEW Architect
LabVIEW Champion
(2,810 Views)
