Serial Packet Question: How to calculate CRC
Thanks Mathew, this is a chinese device, manual is really bad... the only thing i got was the CRC calculation code, and this information:
D14:CRC checking value from the 4th data byte
so annoying that i dont have more infomation! i really appreciate if you can help me on this!
thanks!
Message 11 of 17
(2,258 Views)
Mathew, here is the definition for the packet:
00 01Header fixes at A5 09
02Data Length (its fixed at 0C)
D3 D4First Sensor Id
D5Data Type:60=Sensor Reset, 61=Periodical signal, 62=Status Change Signal
D6 D7Second Sensor Id
D8Second Sensor Status11= Closed   10= Opened
D9Battery StatusA0= Battery Charged   A1=Battery Discharged
D10 D11First Sensor Value
D12 D13Second Sensor Value
D14CRC
hope it helps!
thanks
Message 12 of 17
(2,256 Views)
Here is the LabVIEW version of the code above. I would need to know your data definition better to know what the CRC is actually being calculated over as well as what as the expected CRCs for the data you posted. This would verify this code.
Update: Stripping the header from the data I also calculate the correct CRC (last byte of what you posted) so this code should work for you.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 13 of 17
(2,255 Views)
Mark, thanks so much!!!!!!! thanks for your time.
Message 14 of 17
(2,249 Views)
Mathew! thanks so much! your example worked perfectly!!! you and Mark helped me so much in understanding this complex calculations!
thanks!
Message 15 of 17
(2,248 Views)
So, the A5 09 0C is not included in the CRC calculation.  If you strip those bytes off and feed the next 11 bytes to the CRC calculator, you should see the CRC is the last byte.
Message 16 of 17
(2,238 Views)
To further clarify, you can determine if the CRC is correct in one of 2 ways. You can strip the last byte off (as well as the header) and compare the calculated CRC with the CRC from the packet. The other method which is much more straightforward is to calculate the CRC with the received CRC included. If they match your resulting CRC will be 0x00. If there is any data corruption you will get a nonzero CRC.
The one thing to note is that the larger the CRC the less likely you can get a matching CRC with data corruption in the packet. So, it is possible to receive a corrputed message and have the CRC match. On a 32-bit CRC the odds are extremely low. On an 8-bit CRC it is more likely to occur. You can calculate the odds yourself: "Typically an n-bit CRC applied to a data block of arbitrary length, will detect any single error burst not longer than n bits and will detect a fraction 1−2n of all longer error bursts."
Mark Yedinak
LabVIEW Champion
Message 17 of 17
(2,232 Views)
