Serial Pallet Scale Interface
Read the manual.  You need to send the 'R' command (unless you set the output format to continuous) to get a reading.  Get rid of the bytes at port, and set the byte count to a number larger than the number of bytes you expect back
Message 11 of 13
(924 Views)
It is amazing how you gave that same exact instruction back in message #4, yet the poster either didn't seem to read or just didn't follow it.
Message 12 of 13
(914 Views)
Thanks for the Input RavensFan! 🙂
Message 13 of 13
(900 Views)
