Serial Port Error code
Hi all
   I want to communicated with Serial Port Send command and get right as below snapshots:
 1) I used to Serial_assist Tools when power on get initial message from product and send"AT+SELFTEST=TEST" get right code.
 How to use labview set up serial port ignored first time initial message and send"AT+SELFTEST=TEST" get right code.
(2,610 Views)
Hi Sam,
two notes:
  • Don't use local variables when the terminals are unused next to them!
  • Don't use BytesAtPort!
Setup the port, send your command and receive the answer - without local variables and without BytesAtPort!
(2,572 Views)
Hi GerdW
  Thank you for you reply,I changed it as you mention get as before,if other need to setup it,thanks!!
(2,569 Views)
Hi Sam,
no need for that wait function, the VISARead will wait for 512 bytes (or TermChar) anyways!
Do you have a manual of your device describing the comm protocol? You need to follow the guidelines written in there like:
  • When the device sends two messages you need to read both.
  • When the device sends a "binary" message you maybe cannot use a TermChar.
Read the details in your manual!
(2,560 Views)
Hi GerdW
   It's a earbuds product,client provide baudrate and cmmand"AT+SELFTEST=TEST",then back command as“;g-sensor:OK;P-sensor:FAIL;PPG:FAIL;has_dc:OK”.
The problem is when power on with the earbuds,will out a initial message,first time send command and get wrong measage, hold on power send command again will get right meassage.
I think that if ignored inital message and clear it then send command will get right code,but I don't how to configured it,could you give a idea for this,thanks!!
(2,557 Views)
Hi Sam,
Read the initial message, then send the command and read its response.
So you need VISARead (maybe with timeout error handling), VISAWrite, VISARead…
(2,552 Views)
