Serial Port and VISA in Winows 7 starter
Hi Dear;
I want to use serial port with labview in windows 7 starter.(windows 7 starter that instlled in 10.1" hp netbook.)
NI VISA can not install in this OS;
I install Labview 7.1 on this OS but use of serial port have error yet.
what is my problem?
thank you.
(4,073 Views)
You will need to upgrade LabVIEW to a newer version.
LabVIEW 7.1 came out long before Win7, so it does not officially support Win7.  There is a chance you can get it to work.  You may want to try to install a newer version of NI-VISA than whatever is with your LV7.1 discs.  If you're lucky maybe there is a version of VISA that is compatible with Win7, but still supports LV 7.1.
(4,055 Views)
I download NI-SERIAL 3.6.0 that support windows 7 but Unfortunately setup can not continue an show this message: " This product does not support Windows Starter Edition."
Also I try to setup LabVIEW 2009 but again show above message. " This product does not support Windows Starter Edition."
(4,028 Views)
Look at Installing NI Software on Windows 7 Starter Edition found when I found this thread.
Another possibility would be to avoid Win7 Starter and either upgrade to a better Win7 version, or go back and use Win XP.
(4,018 Views)
Thank you
I upgrade windows 7 starter to windows 7 home base and my problem be solved.
(3,998 Views)
