Serial RS-232 Comunication in LABVIEW
I would like to know how to use the VISA blocks in LABVIEW 7.1 to perform a serial comunication using RS-232. I have a pH sensor that sends the pH level using the RS232 interface, how do I read this sensor with LABVIEW ?
(3,710 Views)
Search the LV example for rs-232. Many examples of serial communication ship with LV.
(3,700 Views)
Hi
Do a search on "serial" in the NI Example Finder in LabVIEW. The Basic Serial Write and Read.VI should be a good starting point.
Let me know if you need more help
Regards
Meister
NI Denmark
(3,699 Views)
What kind of ph-sensor are you using(manufacter)? Search on their homepage for LabView serial drivers
for the ph-sensor you are using, or earch for it on this website. If there are no Labview drivers
for this sensor you would need a programming handbook with all information about programming the
serial interface and write a LabView driver yourselve... better search for it first!
Greetings
Tom
(3,698 Views)
Where do i find the programming handbook ?
(3,686 Views)
In any way you have to contact the manufacturer of your ph-sensor. Ask them for LabView drivers
and if they don't have any drivers ask for a serial programming handbook.
Greetings
Tom
(3,682 Views)
