Serial VISA read timeout
Then the problem is not with LabVIEW. The settings are wrong, the command is wrong, or the cable is wrong (irrelevant that it works with a different device). What does the vendor say? Their tech support should be able to troubleshoot the issue.
Message 11 of 17
(2,129 Views)
Are you sure "Stop Bits" is supposed to be set to "10"?
Bill
CLD
(Mid-Level minion.)
Message 12 of 17
(2,125 Views)
To the VISA API, that is 1 stop bit.  If the OP used the ring, it would show "1.0".
Message 13 of 17
(2,113 Views)
I forgot all about that!  Smiley Embarassed
Bill
CLD
(Mid-Level minion.)
Message 14 of 17
(2,098 Views)
Ugh, think I've tracked it down to a poorly soldered jumper connection. Thanks guys.
Message 15 of 17
(2,091 Views)
Ugh!  Cold solder joint!  I hope you can touch it up and it works.  🙂
Bill
CLD
(Mid-Level minion.)
Message 16 of 17
(2,088 Views)
Yea,  "The bigger the glob the better the job!"  That will get you every timeSmiley LOL
Message 17 of 17
(2,083 Views)
