Serial comms works in VI, but not in application
Hi all,
I am reading out a vaccum pump status in LabView. It works in the VI itself when running it in Labview, but after building the application the communication fails. The main VI has two Sub-Vis for reading and writing the data which show up in the project as dependencies, but from the VISA instrument LIB only the Init VISA VI shows up as it is used in the main VI. I can't see the Read/Write SubVIs. Is this causing the problem?
Ralf-Peter
Message 1 of 9
(2,901 Views)
Are you running the executable on the same computer as the source code? If not, then maybe you have not installed the NI-VISA drivers? Could you upload the part of your code that handles serial communication?
Message 2 of 9
(2,878 Views)
Hi Gregroyj,
the source code and the Executable are running on the same computer The system is Labview 2016. Is there maybe a problem with the Application builder trial license?
I have appended the VIs as ZIP file.
Message 3 of 9
(2,850 Views)
DO NOT USE THE BYTES AT PORT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (still not enough emphasis).
It appears that your instrument is using an ASCII protocol.  So use that to your advantage.  Any competent ASCII protocol uses a termination character to know when the message is complete.  So turn on the termination character, set the termination character to what the instrument uses (based on your code, it is a Carriage Return, 0xD), and just tell the VISA Read to read more bytes than you ever expect in a message.  The VISA Read will stop when that termination character is read and you now know you got the full message.
In your current setup, you are running into a race condition where you are trying to read before the full message is received and you are getting partial messages.
GCentral
Message 4 of 9
(2,842 Views)
@Ralf-Peter wrote:
Hi Gregroyj,
Use this project file, I hope it'll work.
Message 5 of 9
(2,840 Views)
Dear Sabari,
thanks for your reply but I can't open it as your LabView version is newer than LabView2016
Message 6 of 9
(2,833 Views)
Here go with LV 2016 version.
Message 7 of 9
(2,805 Views)
Hello Sabari,
thanks for your help. This version works well. So, where is the difference from my attempt?
I've been working with Labview since 1995, but never had an issue like this before so I'm very interested how to solve this.
Ralf-Peter
Message 8 of 9
(2,781 Views)
@Ralf-Peter wrote:
Hello Sabari,
Ralf-Peter
Do you installed NI-VISA driver?
Do you did it? >> While create an executable you've to add main VI under application properties>> source files>>startup VIs category.
Message 9 of 9
(2,759 Views)
