Serial communication cause crash of LabView
I'm traying to make a serial communication with Labview. The problem is that the programm always crash (no error popup but only LabView freeze) when I read or write with VISA.
I'm working with a converter module (ADAM 4571) which convert Ethernet to RS-232/422/485. The module is mapped on the computer and work similar as a COM port. I tested the connection with Terminal of windows and its work. That mean that isn't a Hardware problem.
I did the same communication some week ago with the same hardware and didn't have a problem. I don't understand why it don't work now.
I give in attachment my code but it isn't particular thing exept for the block which set Buffer (which is requiered for my module) but if I remove it the problem persists.
Does anyone have an idea what can be the problem?
Jérôme
(2,946 Views)
Maybe I forgot some important informations.
- When I try to write I can see that the informations are sent before that the programm crash.
- I tried with another computer to be sure that is'nt a problem of LabView on my computer but the problem is the same.
Regards
Jérôme
(2,936 Views)
Accepted by topic author Marchj
Ok, I solved the problem.
The version of the driver for the mapping of the converter module wasn't exactly the right now I change it and its work.
Jérôme
(2,924 Views)
Hi Jerome
Its working fine here..(i use LV2009)
BTW..what is your LV / VISA version
(2,919 Views)
