Serial communication using VISA
Hello everybody,
I need to communicate with a device connected to my COM1 port. I want to use VISA and the data returned by device isn't always the same size but I know what the maximum number of bytes of the data. If I put the maximum number of bytes in byte count (from the VISA read.vi) will it read the data even if it has a smaller size??
Thx!!
Eric Paulin
(4,053 Views)
Use VISA property node set to Serial Settings >> Number of Bytes at Serial port. Wire this value into the VISA read to determine how much to read.
(4,053 Views)
You may also want to set up a read till end of line character with timeout that will read a variable number of characters until a CR or LF comes in.
Stu
(4,053 Views)
Hi Eric
If a device does not send a known number of bytes, it almost always uses an endcharacter.
The only problem with visa is that you have to supply the end caharcter for reading in a property node and inather property node also enable the endcharacter. You need message based settings:termination character and termination character enabled.
Ask for the maximum and the read should stop after the endcharacter.
greetings from the Netherlands
(4,053 Views)
Additionally you can read byte by byte in a loop until got the all message you are waiting for.
E.g. I had a stupid device at some time, which was not send any end characters, so I had to wait for the checksum from that device calculating it after each byte received from the device and compare it with last byte 😞
Sergey
(4,053 Views)
Hello Sergey,
That's exactly what I have to do :).
Thx!
Eric
(4,053 Views)
I use for such cases a while loop, executing every 200 ms (for ex.) and
the functions "bytes at serial port" and "read from port" until the
numbers of bytes is zero.
Niko
Eric Paulin schrieb:
> Hello everybody,
> Thx!!
> Eric Paulin
(4,053 Views)
