Serial communication with 9 Data bits
I have a problem with serial communications in Labview. I need to
transmission with the parameters 9600baud and 9 Data bits. In the serial
port init.vi it is only possible to set 9600 baub and 8 data bits.
Is it possible to initiate a serial communication with 9 data bits?
Holger Decker
Message 1 of 12
(5,673 Views)
hi,
the same question you can find already answered
by Kevin Kent - 7/6/1999- look @ "9 bit serial protocol" ; maybe you should next time first use the
advanced search function in order to find answers
Message 2 of 12
(5,673 Views)
But i only can find the questions from the last month. How can i get the
question from the 7/6/1999?
"wha" schrieb im Newsbeitrag
news:506500000005000000B4400000-999158726000@exchange.ni.com...
> hi,
Message 3 of 12
(5,673 Views)
Holger,
I believe this link is what 'wha' is referring to. Also, its a long link-name, you may have to copy and paste it in your browser.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000C0000000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
Does anyone know why long link-names are not fully functional without copying/pasting method? This is a new problem I hadn't seen here but recently - thanks, Doug
Message 4 of 12
(5,673 Views)
> recently
I think it's your mail program, not the newsgroup. I'm using Netscape
Communicator 4.76 and clicking the link works fine for me. Is your mail
program wrapping long lines?
-Steve
Message 7 of 12
(5,673 Views)
"Steve Nicholson" wrote in message
news:3B9CCF99.E5F66C9B@AMSPAYsteveandmimi.com...
> > recently
Using OE and it worked for me too.
Message 8 of 12
(5,673 Views)
thanks.
Message 9 of 12
(5,673 Views)
thanks.
Message 10 of 12
(5,673 Views)
It appears that the new Developer Zone software is cutting the links off at the first "&" in the link.
Message 12 of 12
(5,439 Views)
The advanced search gives you the option of changing the date range. I don't think the one star rating is fair because you failed to expand the search range.
Message 6 of 12
(5,673 Views)
