Serial communication with generator and NI USB 6008
I link my computer with an other screen (an other computer), VisaWrite doesn't show any error. But I don't see anything on this screen for port COM which is connected to my computer. Normally, I should see the counter value on this screen because I did serial communication. I don't understand what I should add to my programm to work correctly.
Message 11 of 15
(841 Views)
Hi ki4,
Why should a "screen" show anything just because you connect a serial communication cable?
There has to be a tool (aka "some software") reading the COM port of that other computer and write that data to the screen!
Message 12 of 15
(839 Views)
We can't not configure all that on labview in my computer? and when I run the programm, the port is show on the screen and show the values counter? I can not add something to my programm to send values counter to this screen?
Message 13 of 15
(834 Views)
Imagine for a moment that it's possible for me to write some code on my computer, and then force your computer, without you installing anything or trying to receive anything, to do various things.
This probably wouldn't be so great for security...
GCentral
Message 14 of 15
(828 Views)
Accepted by topic author mimi99
If you have created a VISA serial port link between two computers with LabVIEW installed, you should be able to open LabVIEW on the second computer and run a While loop with the VISA Read for the appropriate port (on the 2nd computer - it may not be the same name as the first) and receive the message.
Is this the expected result? If so, has it worked?
GCentral
Message 15 of 15
(820 Views)
