Serial communication with hex
How do I send data in hex to the serial port?
Is there a way to convert hex string into numbers?
____________
Frode Efteland
(3,974 Views)
Have a look at the string functions, the additional string to number
functions. There you find all you need.
Niko
(3,974 Views)
I have a hex string "CA00 0120 00DE" to send to an intrument. The string is
in "hex display". How can I convert it from byte to byte into numeretic
format?
"Nikolai Maris" wrote in message
news:3E76E3F1.1B42A543@ib-mut.de...
> Niko
(3,974 Views)
Hi Frode
If you already have your values in a string you need not to convert them,
because the "write on serial port.vi" function or the VISA functions expect a
string as input for the data to send.
If you want to convert them into numeric bytes, you can use the "string in byte
array" function.
Niko
(3,974 Views)
Thanks Nicolai!
Now I've found the right track. Thou, I'm not using the VISA serial
communication. Is it as simple as the standard one? As an extention?
Frode
news:3E7703DE.81718251@ib-mut.de...
> Hi Frode
expect a
byte
> array" function.
> Niko
(3,973 Views)
I always use the serial port vi's and run very good with them.
Niko
(3,973 Views)
