Serial communication with microcontroller ....plz help urgent
I am building a robotic arm and will be using labview for inverse kinematics calculation. I need to transfer those values to microcontroller attached to the arm.So what are pre requisets for serial communication between controller and arm. What daq drivers i have to install??? what are steps involved for the communication?????
(4,361 Views)
there are several shipping examples that give the basics of interfacing with serial ports
one other thing to think about is when you deploy your executable code to your target system be sure to include the visa runtime engine in your installer or make sure it is installed on the target machine
- James
Using LV 2012 on Windows 7 64 bit
(4,355 Views)
For serial communication, the only driver you need to install is VISA.  You then use VISA Read and VISA Write to read from and write to a serial port.  You specify which serial port by choosing the appropriate VISA resource as in input to the VISA functions.
(4,353 Views)
thanx a lot..
(4,348 Views)
This block serves to configure the serial port communication and data transmission generate this program download it even Arm cortex m3 microcontroller. The while statement monitors a change to the Up button, if this happens to generate random data and writing to the serial port at intervals of 100ms began, if we press the Down button stops this process, stop the program by pressing the Select button, more information https://decibel.ni.com/content/docs/DOC-35104
(4,068 Views)
