Serial port init frequency
I currently use LV to dialog with an RS232 device via the serial port.
How often does I have to re-init he serial port?
For the moment, I do it each time I want to send a string to the device.
(3,475 Views)
Zen writes:
In theory: Once. It depends on whether you have an initialisation
phase or want to avoid it. If you don't need high speeds, you can
leave it the way it is.
Johannes Nieß
(3,475 Views)
I send a string everery two seconds, and raed the reponse from the
device. I just don't know if the serial buffer is emptied before
receiving the response string. If not, there might be left old caracters
causing a wrong response string.
(3,475 Views)
Zen writes:
You should use VISA and forget about the low level stuff. If you have
non-binary communication (printable characters only, CR/LF) you can
try to read e. g. 1000 chars and VISA returns the string until the
first linefeed. And you get a timeout loop for free 🙂
Joha
nnes Nieß
(3,475 Views)
perform a "dummy" read of the serial port and throw away the data before
sending the serial command.
that way you know the buffer is empty before you expect data.
Stu
"Zen" wrote in message
news:3A3788B7.17B95C8@lure.u-psud.fr...
Stu
(3,474 Views)
