Serial port not working on installed machine
Accepted by topic author MarkGreally
Does the drop-down in the application populate with the list of serial ports?
Are the COM ports the same? Your application reads the Serial Port at the very start of the application which means that changing the value in the drop-downs does nothing as the controls have already been read by that point.
You need to find a way to re-read the controls (e.g. in an initialise case of a state machine) if the user changes the value.
(blog)
Message 11 of 15
(1,606 Views)
The image attached shows an image of MAX on the target machine.
I then tried to do a read in the input/output section and I get a read Operation Error.
VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
or
VISA: (Hex 0xBFFF003E) Could not perform operation because of I/O error
Message 12 of 15
(1,601 Views)
SAM_SHARP you are a legend. I changed the control to a constant. I'm glad it was just a programming bug on my behalf as installation was looking like it was going to be a pain, but all is good now.
Message 13 of 15
(1,589 Views)
A constant it's NOT good practice. What happens if the cable is moved? Fix the way your port is selected.
Message 14 of 15
(1,579 Views)
I will of course. But I know where the problem is. I thought it was with the installer.
Message 15 of 15
(1,576 Views)
