Serial port overrun error. When sending e-mail using VI
I get the following error when attemting to send an email via this VI. It's my first attempt at automated e-mail.
Chris
One should welcome adversity as an opportunity to excel.
(2,883 Views)
That dialog is simply showing you two possible reasons for the error. In your case, the second reason is the applicable one. Basically, the server was not accepting a connection on the SMTP port. This is confirmed via www.nwtools.com. Check the server that you're trying to connect to.
(2,870 Views)
WOW. That is a sweet web site!! I will contact our IT department.
THANKS AGAIN!!! (you have helped me before I think)
Chris (Daddy-o)
(2,859 Views)
