Thanks Ben. I did accidentally post my response to the other LabVIEW performance question posting. I have pasted the relevant information here:
"We have reproduced this issue here on a Pentium 4, 2 GHz, single CPU, no hyperthreading, 512 MB RAM, running Win2k SP4. Similar behavior is also noted on WinXP.
There is a workaround for the slow saving behavior. Saving via File - Save or CTRL-S is very slow when many VIs are in memory. However, if you edit a VI, close it, and then answer "Save" when prompted, it saves very quickly. You can see this as follows:
- Open loader.vi, set it to load 1000 copies and open front panels. Run the VI.
- Hit CTRL-N to create a new VI. Be patient.
- Select File - Save A
s, give it a name, and save. Once you click save it takes 10 - 15 seconds on my PC
- Drop a numeric constant on the diagram. Hit CTRL-S. This took another 15 - 20 seconds on my PC.
- Drop another numeric constant on the diagram. Close the VI, and when prompted, click Save. The VI saves and closes very quickly.
R&D will continue to investigate the performance behavior. Thanks again!
Kileen C."
