Service Name appears with RT Project in dev mode but not while deployed
Exactly as the title says, I have had no network problems with this project for the last several months.
If i run the my main.vi while on my PC the service name appears. When i do a clean build of the project and deploy it. The service name is missing from dumpinfo. what can I do?
(891 Views)
Can you confirm that the application is deployed on the target by going to the targets Dependencies -> New -> Real-Time Application
And then go to Source Files -> Select the VI you want to run on startup and click build
Some other recommendations would be to:
1.) Verify Service Locator on Target:
Use NI MAX or SSH to confirm that the Service Locator is enabled and running on the RT target.
2.) Include Service Registration in Startup VI:
Ensure the code that calls 'TCP Create Listener' and registers "superboy" runs in the Startup VI and is included in the build specification.
3.) Static vs Dynamic Ports:
If possible, assign a fixed port instead of 0 to avoid dynamic port issues.
(841 Views)
wsimpson0050.
Yes i have the Main VI set as startup. I think I need to keep my Main as the entry point of my program, as it contains all other VIs.
The TCP listener is in the "Network Engine.vi".
I know the is enabled and running because i can visit port 3580/dumpinfo? ( in my case "http://10.0.5.83:3580/dumpinfo?") and the service names appear. all except "superboy"
The reason why I am using a service name and port 0 is because it auto assigns a port. This has actually worked for me in the past. I actually have another project running multiple service names. This project has been running for several months without any issues.
(832 Views)
I would try to log the error that is happening while the system is deployed by saving the error to a text file. I would also just try to specify the port and use a timeout of 1000ms (or replace the 'TCP Create Listener' with the 'TCP Listen.vi').
(821 Views)
I am at a complete loss, I cant get anything to log. Its like
even within the main vi if there is a single error on initialization then its logged to the same directory...
Nothing when I try to browse it.
(807 Views)
Accepted by topic author elibarber
UPDATE: Sometimes when we are at our lowest, we find the solution.
Creating a new build spec (not copying the old one) solved the issue. No idea why.
(798 Views)
