Servo motor
I have Hitec standard size servo motor which I want to control using sbRIO-9636. The specifications of this servo motor are:
  • Voltage: 4.8-6.0 Volt
  • Direction: Clockwise/ Pulse Traveling 1500-1900usec at 50Hz.
I need to control the position of servo motor's arm by sending it PWM signals from sbRIO's DIO. I need some assistance how would I generate PWM that would move the servo according to angle I set over front panel.
Regards.
(2,668 Views)
never worked with a RIO, but there is a White Paper of NI showing how to generate different signal forms: https://forums.ni.com/t5/Example-Code/NI-LabVIEW-RIO-Evaluation-Kit-Additional-Examples/ta-p/3983750
Perhaps this helps. However, depending on what you try to do, you can try to use an Arduino microcontroller which can directly generate a PWM output signal without consuming time on your FPGA...depends on how time-critical your application is.
Hope this helps,
Christian
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
(2,632 Views)
