Set Digital Output for Modicon 340 through Modbus Ethernet
I used modbus Ethernet example vi and am able to read input coil status of quantity 512
If starting address is changed above 511, VI returns 6002 error.
As per below concept, how can I write  to output coil
Output Coils are assigned the block 1-9999
Input Coils are assigned the block 10001-19999
Input Register are assigned the block 30001-39999
Output Register are assigned the block 40001-49999
I also tried sending command directly to TCP IP write like 05 00 AC FF 00 to set a coil. Still its not working.
Can anyone inform how to proceed. Any example or command structure is highly helpful
Thank you
Message 1 of 1
(2,378 Views)
