Set Status Bar position
Hi!
I'm currently developping an application which requires a status bar. I integrated it using a .NET container on my front panel. I would like to programmaticaly set its position on the front panel but I must admit that i'm lost seeing all options offered by the property nodes.
Can someone help me to choose which option to use ?
Thanks !
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,802 Views)
Zyl,
you mustn't get mixed up by the number of properties in this issue 🙂
Well here is why:
- The .NET assembly gives you a whole bunch of methods and properties which are used to interact with the assembly. These are not used for positioning the container
- Each element in LV has its own properties, too, which can be handled by VI Server. All FP elements have generic properties, such as position. THIS is what you like to change.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,799 Views)
Thanks ! You helped me a lot !
(2,793 Views)
