Set a autocounter for file saving
Hi
I was wondering if antbody knows of any quick tricks for autosaving files with a look-up to prevent overwriting.
What I would like to do is set the file path and for the labview routine to look in that path for the last file name and add 1 to the file name so the last file is not overwritten.
e.g.  path:               C:\Ashley:\todays_runs
        start counter:  001
(2,874 Views)
Hi Ashley,
This VI should serve ur purpose
just workout on a logic to increment run numbers
regards
Dev
(2,863 Views)
