Set a ring value programmatically
I use a ring control that is filled in with values
The progranm value  is example 0.001
Ring
3
1
0.1
0.01
0.001
0.0001
0.00001
etc
How can i set the value of the ring programmatticly,
so the 0.001 is selected?
see attached example setRing.vi
Kind regards, Ben Arts
(5,708 Views)
You are using an Enum, not a Ring.  If you change it to a ring, you can set the values to be whatever you want.  So then you can just write the 0.001 to a local variable of the ring.
(5,703 Views)
Thank you for answer.
I tried but doesn't work.
see attached example SetRing1.vi
Were is the mistake?
Kind regards Ben Arts
(5,701 Views)
Change the data type of the ring to DBL and then edit the items to make the values match the displayed text.
(5,697 Views)
