Set data for the x-axis
I made a program which allows the user to configure and measure Temperature and voltage using a DAQ device. I also set a possibility for the user to save his data of his test to lvm file and then upload and read it on a waveform chart. My problem is that while the user  gets multiple plots represented in the y axis (the different Temperature/voltage channels signals of the DAQ), the x-axis is set to time by default.
How can I change it? I would like to allow the user to change the x-axis from time to one of the plots of his tests data.
for example, lets say I get 2 signals of temperature (mod1/ai0 and mod1/ai1) and 2 signals of voltage (mod2/ai0 and mod2/ai1) on the y axis (amplitude) during 3 hours (represented in x-axis) and I would like to allow the user the option to play with the data so he can see temperature on the y axis as a function of the voltage on the x axis (instead of time) and the option to configure any kind of combination while the program is running (set mod1/ai0 in the y-axis and mod2/ai0 in the x-axis, for instance).
I have tried various things but nothing seems to work. It looks like it is very easy to change plots between multiple Y-axis with property node of "Active plot" and "Y scale index" but I can't figure out how to change plots from the Y-axis to X-axis and vice versa.
I hope this clumsy message is somehow clear..
Thanks a lot in advance,
Shahar L.
Detectomat Gmbh
Hamburg, Germany
(2,680 Views)
Hi Shahar,
You will have to use an XY graph, not a waveform chart, if you want to set the X-axis data.  Under "Find Examples", see "Fundamentals"..."Graphs and Charts" for some examples of XY-graphs and how to use them.  You can't change the X-axis data of a waveform chart, as you have discovered.
Hope this is helpful...
Diane
(2,675 Views)
Hi Diane,
Thank you very much for your reply. of course you're right and I need to use a graph.
this was the first part of the solution. the second was to use 2 Select Signals vi's and assign 1
to the x-axis and the other to the y-axis.
(2,645 Views)
