Set fixed width to legend in graph
i have a graph on a panel that has an enabled legend.
Now o want to set the width of the legend to a fixed size.
For this there is the property Legend.Size.Width.
This property only works if Autosize is disabled.
The question is now:
It looks as if the size of the plotname-field is always the same and only the small graphic gets bigger?
But i want to increase the size of the visible plot-name.
How to do this?
Thx
(2,854 Views)
The only thing I came up with is to leave it in Autosize, change the plot name to something that has the length you desire for the name field and then turn Autosize off and put in the name that the plot should really have. Like so. (see attached VI)
(2,837 Views)
