Set own X axis data point in Waveform Graph
Here it goes,
now im trying to format my waveform graph in LabView.
i have my own set of data which is currently in 2D array and it has 1 colume and 11000 row of data.
i want to use this data to be my X axis.
any idea on how should it be?
Message 1 of 8
(5,562 Views)
And what do you want to use for your Y data?
Message 2 of 8
(5,556 Views)
19475i221ACCB734425D53
Something like this.
im able to plot the graph now with Column Y and Z but i cant find ways to set the X axis with the X column.
is it possible to do it?
Message 3 of 8
(5,546 Views)
Message 4 of 8
(5,535 Views)
yes, i want it to be show in order
i have seen these 3 threads but it seems that i cant find the solution i needed.
but firstly, is the scales in waveform graph editable?
i, still exploring the property node trying to find ways of doing it, but still cant find it thought.
Message 5 of 8
(5,520 Views)
You cannot edit the scales the way you want. Neither the chart, graph, or XY graph allow fot arbitrary or text scales. The links above are the only way I know of.
Message 6 of 8
(5,515 Views)
crap.
so there's is no other way of displaying the values i want for X axis? cos in the end, i might have to export the graph out to microsoft word.
from the method i see, after exporting, the X axis value in gone as it is not together with the graph.
Message 7 of 8
(5,507 Views)
Message 8 of 8
(5,496 Views)
