Set picture size onto MS Words
HI,
     is it possible to adjust the size of the picture that is being added to MS Word using Append Image to Report VI?
currently, im using Append Image to Report VI to attach the picture into MS Words but some of my picture are too big so it auto resize it in the MS Word
while the smallers picture is alright. so now i was thinking is it possible to adjust the picture to the size i want it? like the height and length.
currently, the smaller picture looks big while the other bigger picture which has been strink looks small, so now i would like to adjust the picture for the small picture to small.
(2,661 Views)
hi 64864050
 Using Append Image to Report vi ,it is not possible to scale the image to the preferred size..So you need to think of scaling the image before and then adding to the report.
Thanks and regards,
srikrishnaNF
Srikrishna
(2,653 Views)
You can use Read JPEG File.vi (or other format) to open your image.
Then, use unflatten pixmap.vi to change it into array, and manipulating array to get smaller image.
After that, use flatten pixmap.vi, and Write JPEG File.vi to save it back.
(2,633 Views)
