Set the PPS source on the X410 to "EXTERNAL" using LabVIEW
Dear all, currently we are trying to use the external PPS IN as a start-trigger source, but we cannot set it from LV 2023 Q3.
We looked into the configurations available to be set using property nodes on the HOST side, but it doesn´t have such an option, also the USRP driver doesn´t have a VI for this scope.
We know that in the USRPrio driver there was a specific VI "CPTR PPS source.vi", but this cannot be used with the X410 because we cannot open a USRPrio session.
Is there an easy way to do it, or do we need to look into other directions like the UHD driver, and if this is the case, is there anything ready to use for such simple setting?
Many thanks in advance.
Message 1 of 1
(594 Views)
