Set the limit of integration
Hi guys,
I am new to labview. Currently I am using Labview 8.5 to connect with Tektronix TPS 2024B osciliscope for calculating power. I use the example code from Labview to start with. I integrate the power but I only want the first cycle that is between 0 to 0.1. Are there any ways to set the limit of integration in labview?
Thanks for your help!!!
(3,291 Views)
Accepted by topic author day831
Hi day,
when you want to integrate just a part of your waveform you need to integrate just this part!
Simply get the interesting part of the waveform...
(3,284 Views)
