Set thermocouple scale to table for one channel within task
I think this problem is solved. I personally favor Ali's solution for my application. It's simpler. I don't want to make a custom scale for my thermocouple. I'd rather use NI's table which is already there. Still haven't had a chance to try out either one, but I think they both will work.
The option I mentioned in my first post, having a pre-made virtual channel for the one thermocouple I needed to isolate, did work. It turns out that you have to actually create the task and add the virtual channel to it before you can use the ScaleType property. I'd rather not have to do that, though.
Message 11 of 12
(587 Views)
Just tried Ali's solution and it worked great. Thanks to everyone for their help!
For future reference, I'm including a snippet. This for loop accepts an array of physical channel/enumerated sensor name pairs and creates the channels based on their sensor name.  The relevant case is shown.
24210i1C790B0970AA811C
Message 12 of 12
(571 Views)
